Can anyone please give a try on their
Ibiza/Cordoba to see if the procedure to programm the remote works as well with open doors (or at least with an open door)?
That's because I just replaced two of the sensors for the closed door (the ones that sense wheter the door is closed or not) and found out that the other two were not working too... To the central unit it might seem that the door is open all the time, hence not allowing for the reprogramming of the remote... Someone that already done the resync before corectly (so that he is sure he'll not remain out of sync
) could please try to resync with at least one open door just to be sure wheter or not it will work that way (the procedure indicates to do it doors closed).
This might
help all us having problems in resyncing, since I observed that those sensors deteriorate over time (mines had a few contacts oxidated - I think that's the correct word
, the contacts are internal and one can not see them from outside, so if the sensor is not working one would never know.
I founded a simple procedure to check the correct functioning of those sensors (apart for the driver's door, which would make a sound when lights are on, engine off and door open, sound that has to stop when u close the door): lock the doors with the key (but keeping one door open). The alarm will activate and u have a short time (around 30 seconds) to "close" all doors so that they will be considered for the alarm, for this time keep pressed the sensor "simulating" that the door is closed. When the small led on the driver door changes the blinking it means the alarm completly activated and u can start the test. Release the sensor u kept pressed and the alarm should go off making sounds if the sensor is working corectly. If it is not going off u probably have one defective sensor on that door
To shut off the alarm u just have to use the key on one of the door and unlock the car. Try this on all doors and u will find out which sensors are not working ... If u did not manage to resync your remote please try this out in order to check if all door closing sensors are working, at least we could that case pinpoint the
problem.
Hope someone can try this out and let me know whether or not the resync works with open doors as well or only with closed doors
Rumburak.
