Remote key part #
Jan 8, 2007
2,958
Wiltshire
Does anyone know the part # for the MK3 433.92 MHz standard remote fob?
SEAT have provided me with a 433MHz variant which appears to be for the MK2: http://seatcupra.net/forums/showthread.php?t=167555&highlight=6K0+959+753
This one is part number 6K0 959 753B, 433Mhz
Thanks in advance
(Oh, and I can't get an Alhambra flip key variant as I've lost my main key and SEAT will only replace keys against the chassis code...)
Jan 8, 2007
2,958
Wiltshire
That's the one I need Mike, AFAIK they only work with 433.92
If anyone has the part number so I can tell SEAT how to do their job properly it'd be appreciated
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
remote fob 6K0 959 753B
same part number for :
01-02 Alhambra
03-05 Alhambra
96-00 Alhambra
97-99 Cordoba/Vario
99-02 Cordoba/Vario
97-99 Ibiza
99-02 Ibiza
96-03 Inca
97-99 Toledo
Early keys seemed to have just the general frequency range stamped on em whereas the newer vehicles had a more precise frequency code hence them being different and working the same.
has something to do with public broadcasting right's (radio signal's) and stuff like that from memory
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
the remote section should work fine - same part as listed above
it's only euro nosing that means we have to have the specific freq listed now that's all
Jan 8, 2007
2,958
Wiltshire
OK thanks for clearing that up. Interesting as the SEAT techie said he wasn't able to program the remote fob. I'll try myself later, though he reeled off the correct procedure for doing it.
I'm wondering if it's in any way related to me running a race battery, when left for a few days I get a low voltage code in VAG COM. Just a thought, if it wasn't charged enough then maybe it'd struggle programming the key?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
anything electrical to do you need a decent base voltage for starters and low voltage code errors in VAG COM isn't a good sign
fit a normal one in for test to be sure - wouldn't hurt even if it's only temporarily in fact why run a race battery on a road car ?
Jan 8, 2007
2,958
Wiltshire
Bit of an impulse buy when my original battery was goosed and I was trying to shed a bit of weight, though it is used only as a weekend/track toy.
I normally leave it connected to a pulse charger when it's garaged but my new place doesn't have any electric in there :(
But yeah I think this might have more to do with it, I'll leave it on charge for a few hours and then try, thanks.
Jan 8, 2007
2,958
Wiltshire
Well turns out that was the issue after all :) After a few minutes left on charge the key was able to be programmed and now works fine
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
coolio
btw if it's stored for a while it may be worth looking at disconnecting it from the car itself whilst charging
Jan 8, 2007
2,958
Wiltshire
Thanks for your help Flapper :)
It's generally driven most weekends so it *ought* to be OK. It never used to be an issue when I could leave it on a pulse charger whenever it wasn't driven but my new garage doesn't have any direct electric which makes things more tricky. On occasions the car will lose it's memory, i.e. one touch windows etc but c'est la vie I guess
