ttothec
349
Reading
does anyone know how to remove the internal sensors for the alarm on a mk3 cupra? its the plastic housing in the roof lining just behind the passenger seat?
my alarm keeps going off and i want to see if unpluggin the sensor makes it stop
just dont wanna break anything trying to remove it
any help would be much appreciated
yeh, did that and the alarm still went off... checked all windows doors and bonnet too
wanna see if unplugging the actual sensor stops it
Try bonnet switch check the multi-plug as i've found problems where they fill up with water and make the alarm go off. I checked mine and it was starting to go green with corrosion, i cleaned it and filled the connector with silicon grease never had a problem since.
