Removing AirBox **GUIDE WITH VIDEOS OF SOUND**
VRSLOZ
Formally SC16v
May 1, 2010
3,255
Costa Del Hertfordshire
Tools/Parts needed :
Torx T20 Screwdriver
Hands
Car used :
10 Plate Ibiza 1.4 SC Sport
Time needed :
5 Minutes Max
Difficulty :
1/5 - Incredibly Easy
First off open your bonnet and you'll see this :
We are going to be removing this :
Remove the oil breather pipe (Thanks Elliot!), simply pull it off :
Next we need to remove the cold air feed pipe :
Facing directly infront of the car look to the left of the end of the pipe and you should see a Torx Screw. Take you T20 Screwdriver and remove this :
Once removed you will need to ease the other side off, it's kept on by a simple clip that pushes out and you should then have :
Place both hands on the airbox on either end and lift gently, the rubber bung in the middle should pop off it's holder :
You now need to manovure the box so you can lift it out of the engine bay and place somewhere safe :
Et Voila! All done :
VIDEOS :
Car with the airbox on :
Clicky
Car with the airbox off :
Clicky
Engine view with airbox off :
Clicky
