Removing rear seats
JordanMk3
WackyColouredWheelsFTW
Jan 18, 2010
1,494
Little Hulton, Manchester
Hey guys..
Just a quickie ;)
How do you remove the rear bench and backs? (Seats)
Ive had a look and am a little confused... Also, are they easy to put back in? Its pretty cold and dark outside, so can imagine I will be taking skin off my knuckles..
thanks guys..
Jordan
dalegolf215
UNbanned
Jun 3, 2010
1,151
Rov'rum
For the bench lift it at the front and it will flick up its then just a rod in a couple of locating holes that needs squeezing together so you can pull it out of the holes
The backs
Pull the top catch as if folding them down then there's a catch on one side at the bottom similar to a front door latch just push it back with a screw driver and youl be able to pull the seat back out :)
HTH
Edit think there may be an Allen key bolt on the opposite side to the catch on each of the seat backs also
nightflight
2,677
13
Sheffield
Yep, that's it, one allen key bolt at the front, a bit of plastic trim on the door side runner and a bump stop on the inner runner (might be the other way round) then just slide the seat all the way to the back.
JordanMk3
Jan 18, 2010
1,494
Hahahaha! I'm being held into my car, by one Allen key screw? That will make me think twice about hitting the twisties at 80...
Cheers for that mate! Will give it a go now:)
