removing rear trim in 3 door
GingaByte
Hi,
I recently got a ibiza tdi fr which I plan to put in readers rides once I get a change to take a few pics. Im currently upgrading the audio and am trying to get the trim off at the rear speakers (3 door). Ive removed all screws etc that I can see but I want to check how to remove it before I pull and snap something off.
I did a search so please excuse me if its been said before.
Thanks a lot
:D
dash
389
surrey
After removing the door rubber seal, the the backrest seat needs to be pull down as there is a screw there...I think. There are clips all around as far I can remember. I had to drill the rivets out once u get to the speakers!!! But I had 6x9 fitted under a stealth shelf. Good luck m8.
GingaByte
Thanks, ill give it a go at the weekend, going to try and fit some 6x9 and amp them.
GingaByte
Well ill take a look once I get to them but i've got plenty of sound deadening lying around to pack in there. Even if I stick with the originals I need to look there because there's a huge rattle.
GingaByte
Has anyone had problems replacing the rears with same size speakers as it seems that on the top of the originals it's flat.
