Jamesb
60
19
Does anyone have any tips for which spray paints are best for refurbing alloy wheels pls?
Looking at graphite or anthracite grey
Process looks like,
Cover up tyres and brakes
Sandpaper
Clean
Primer
Paint
Lacquer
Sent from my SM-G960F using Tapatalk
Process looks like,
Sandpaper
Clean
Primer
Paint
Lacquer
Give yourself one day per wheel to get the best results or longer if you need to remove curb damage.
Time is far more important than the brand of paint you choose.
Process looks like,
Sandpaper
Clean
Primer
Paint
Lacquer
Take them to a wheel refurb place and sit back and let them do it properly
Agree with the above.
For a possible £90/100 a wheel I would save the aggro and get it done properly.
If not diamond cut, I’d probably guess that bigger too drop.
Reactions: LR231998
Not the cheap option but get them powder coated, much harder wearing protection for your wheels
Reactions: LR231998
If they’re diamond cut the prices definetly rocket (I’ve had loads of DC wheels refurbed) but still, if it’s a high quality place with good reviews, it’s definitely worth paying the pro’s.
And I can’t stress enough the importance of a well reviewed place with High standards of work. I had my previous diamond cut 18” wheels on my Ibiza FR refurbed and after a good few months the lacquer, finish and diamond cut areas were peeling, fading, bubbling. I only used gentle wheel cleaners. My current Leon Cupra alloys are still perfect (touch wood) so hopefully won’t face this problem again!
Looks like you’re planning on doing the refurb yourself.
Not necessary to cover the brakes if you remove the wheels from the car, and removing the wheels will make it so much easier to rub them down off the car than while still bolted on. Also, removing the wheels eliminates the risk of paint spray drift onto the car’s surrounding bodywork that could happen if the wheels are painted while on the car. Ensure the car is well supported when the wheels are removed - if your car has a space saver spare and jack, don’t rely on the flimsy jack to support the car (they’re known as a ‘widow maker’ for a reason!). It’d be OK to use the ‘widow maker’ if you only remove one wheel at a time though, as you can put the space saver on while your remove each wheel to work on it.
Ensure wheels are fully rubbed down before any painting, to create a good ‘key’ for the new paint to adhere to and to remove any wax, sealant or other protection, otherwise you may find the new paint you apply peels or flakes off after a few months. If your wheels are badly scuffed in places around the edge from kerb damage, then you may need to fill any rough areas around the rim and sand back to be level with - and the same contour as - the surrounding undamaged areas before painting. Don’t use sandpaper for rubbing down - get a selection of different grades of wet and dry abrasive paper and use plenty of water while rubbing down.
When spraying, ideally do this in a dust and draught-free environment to avoid dust or debris settling on the wheel surface. With painting, less is more - use light coats of primer and paint to avoid paint runs and allow sufficient time between each coat for drying. Rub down lightly between each coat of primer with fine grade wet and dry paper and plenty of water before applying the next coat (don’t rub too hard or you’ll remove the primer you’ve applied!) and wipe down the surface with a ‘tack cloth’ to remove any dust / grit that would show up as imperfections through the gloss / lacquer coats when applied.
After a couple of weeks, polish, and apply some wax or sealant as protection.
Lots of videos on the internet on diy wheel refurbishment. If you’ve not already done so, do a google search on ‘diy car wheel refurbishment’.
Edit; if this is your first attempt at a diy wheel refurb, I’d recommend you get l an old wheel from a breakers yard that you can practice on and perfect your preparation, paint spraying / finishing techniques. IMO, its better to make mistakes on a practice wheel rather than on the real thing.
Not sure where you are based but metal magic in Barnsley are excellent. Just had my 17’s stripped and powder coated for £244 including tyre refit and balance. They also do a 1 day service but have a long wait for that one.
