Retrofit DAB+ on Leon ST my2020
witek_77
90
38
PL
Hello everyone. Unfortunately, my 2020 model year Leon ST does not have DAB factory. The car is in the excellence version with 10 "navigation plus. I would like to add DAB and I have a few questions. After changing a few options in 5F, I see FM / DAB in the radio menu, I can attach the DAB antenna, but I do not have it physically, also I have the error of no antenna. I did a little research and see that there are 2 amps. Right and left. Is that correct? Does any of you know how to go about doing this? Do I need to change the wires?
witek_77
90
38
PL
OK. I have made this but on chinese DAB antena. I have antena fault but amplifier is ok.
1. we need to check if we have a connector in the unit. I have used a mirror for this.
2. Buy antenna with FAKRA typ A (black). For example
3. Remove the glove box (6x torx 20)
4. connect the antenna but do not assemble anything yet
5. Recode unit. Open bonnet, handbrake, unlock SFD, go to 5F, adaptations
a) band settings dab tuner band 1 change to EU_BAND_III-N
b) DAB MODE ANTENNA MODE 1
to ACTIVATED
6. Reboot unit. Hold for 40s power button on multimedia.
7. You see FM/DAB. Wait for few minutes.
8. if everything works, put it back together. Buy an antenna with a cable not less than 4m.
9. Go for beer
Reactions: KoNG
