hi all, I'm studying how to retrofit my VZ; I want to replace the external handles and mount those with LEDs. from what I understand, the formentor has the same handles as the golf 8 that fitted them with LEDs as standard.
1) do you confirm it can fit golf 8 handles with code 5h1837205?
2) I should mount those equipped with kessy and LEDs at the front, only with LEDs at the rear, do you know the code?
3) do you know if the cables to power any LEDs reach the handles of the formentor or if I have to use the light cable under the external mirror?
