Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
done and fitted excellent... like the flicker when engine starts ...![]()
+1.done and fitted excellent... like the flicker when engine starts ...![]()
+1.Wasn't too tricky to change once I'd figured out it just needed a bit of brute force to unclip the cover inside the boot door...
mine did too, protected it tho ... although I would have liked it in a Ferrari..Got mine today, took 2 minutes to fit. Disappointed that bulb was sent in just a jiffy bag only. But works fine, and has made a big difference. Thanks to the OP, for the thread.![]()
glad to see ive finally given some good advice on here for once. I imagine they will fit an altea, the fittings should be the same
Nope. No warnings at all (touch wood!) with my facelift Ecomotive. The light pattern is more focused / narrower beam and the colour is a little bit different from a normal bulb, but it's certainly a bit brighter.Does anyone get the bulb error warning due it being and LED??
