reving up please help
Apr 13, 2011
1,971
hull
hey peeps i have only just brought my new seat ibiza cupra tdi on when i got home i noticed when i come to a halt my engine slightly revs up to about 1100 revs at tick over then go back to normal any one any ideas what this could be
Dec 3, 2009
1,638
after the car is on for a while?
I know mine can be quite jittery after stopping for a second but it settles down after a few seconds
krussel
1,713
Hertforshire
Funny this has come up. On Sunday my FR tdi started up with a 1450 rpm tickover :(
It dropped back to normal once the throttle was blipped but on a restart it returned to the higher tickover again. I put it in the garage and connected my battery conditioner up and left it till i came home from work the next day and it started normal (850 rpm) again and has been fine ever since. Strange :shrug:
Jan 11, 2005
680
Barnsley
When my battery was on its way out, it would start with a higher idle speed
Apr 13, 2011
1,971
hull
yer that's the excat same thing my cupra does so what do you think causes it
Apr 13, 2011
1,971
hull
when you turn the ignition on does the battery light come one?
yer when i turn the ignition on the battery light does come on and when u start it up it goes out as it should do are u serspecting its a battery or alternator fault??????????????
Apr 13, 2011
1,971
hull
Have a look if your brake lights are stuck ON.
It sounds like the anti stall is kicking in.
no the brake lights are working as normal its only doing it inertmetantly when u rev it slightly it stops and goes back too 850 on tick over drives apasalutly fine
krussel
1,713
Hertforshire
When it started with the high tickover i just "felt" the battery seemed a bit low which is why i put it on the conditioner. She's sat in the garage all week an ive brought it out today and it started fine. She gets 100 miles on the M25 today.
