Nov 2, 2004
9,334
South Wales
Can someone post up a 115 log please, or even check whats the most mbar its requesting, ideally on Boost 9 or HB9 for old school SPS people.
Thanks.
Code:
	Group A:	'115				Group B:	 Not Running
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP
	0.44	2760	144.4	2200	1850
	0.94	2920	177.4	2200	2320
	1.34	3040	191.7	2200	2520
	1.74	3120	191.7	2200	2520
	2.14	3240	184.2	2200	2430
	2.54	3320	181.2	2190	2400
	3.03	3400	182.7	2180	2380
	3.43	3520	178.9	2180	2350
	3.83	3640	175.9	2180	2320
	4.25	3720	176.7	2190	2310
	4.73	3840	175.9	2190	2270
	5.15	3960	175.9	2190	2250
	5.55	4040	172.9	2190	2230
	5.95	4160	172.9	2190	2220
	6.44	4240	171.4	2180	2210
	6.84	4320	169.9	2180	2190
	7.24	4400	169.2	2170	2170
	7.64	4520	169.2	2170	2160
	8.03	4560	170.7	2160	2160
	8.44	4680	168.4	2170	2140
	8.84	4760	169.2	2160	2120
	9.24	4840	168.4	2160	2120
	9.63	4880	168.4	2160	2120
	10.04	4960	167.7	2150	2100
	10.44	5040	166.9	2130	2080
	10.84	5120	166.2	2110	2090
	11.24	5160	163.9	2110	2090
	11.64	5240	163.9	2100	2090
	12.14	5280	162.4	2090	2070
	12.54	5360	160.2	2080	2070
	12.94	5400	157.9	2080	2040
	13.34	5480	157.1	2070	2060
	13.74	5480	155.6	2060	2040
	14.14	5560	155.6	2050	2040
	14.54	5640	154.1	2050	2020
	14.94	5680	153.4	2040	2020
	15.34	5680	153.4	2020	2010
	15.74	5760	152.6	2010	2000
	16.14	5800	151.9	2020	2000
	16.54	5800	151.9	2010	1980
	16.94	5880	151.1	2010	1970
	17.34	5920	150.4	2000	1980
	17.74	5920	150.4	1990	1970
	18.14	6000	149.6	1990	1950
	18.54	6040	148.9	1990	1950
	18.94	6040	148.9	1980	1940
	19.34	6040	147.4	1980	1950
	19.74	6080	147.4	1980	1930
	20.14	6120	146.6	1960	1930
	20.54	6120	146.6	1950	1930
	20.94	6160	145.9	1950	1940
	21.35	6880	41.4	1000	2250
Thats assuming my cars running right.
Is anyone running a k03s on high boost/boost 9 on stage 1?
For some reason HB/Boost 7 requestes more boost on stage 1 than HB9 on stage 2 according to my logs.
Yours requests 2550mbar daz, mine gets that.
Benny thats exactly the same as what i get.
Heres a log, which might even be on HB/B6 on stage 1.
Code:
 /min	%	 mbar	 mbar
2680	156.4	2190	2110
2960	176.7	2300	2370
3240	183.5	2340	2420
3520	178.9	2360	2380
3760	175.9	2360	2330
4000	175.2	2370	2280
4200	172.2	2290	2240
4400	168.4	2240	2180
4600	163.9	2190	2120
4800	159.4	2130	2040
4960	155.6	2050	1970
5080	151.9	2020	1930
5200	148.1	1990	1880
5320	142.1	1970	1870
5440	141.4	1940	1840
5560	136.8	1920	1820
5640	136.8	1900	1790
5760	135.3	1880	1760
5840	132.3	1850	1730
And thats from a stg1 log? Thats weird, im not that clued up on logs but that deffinatly suggests that its requesting more boost:confused:
Seems weird that we both pulled bad results on the RR too. Just out of interest have you had the updated stg2 map uploaded? I had mine updated when when she went in for a service and seemed abit more punchey after. I yet to log with the updated map to see if there are any differances in figures.
Might be worth a PM to kev he may be able to explain in detail why they differ?
I had my stage 2 code done just over a year ago, no idea if there was an update since then.
I know requested boost isnt the be-all and end all of the map, but it just seemed a bit strange that at its peak its only requesting 17psi insstead of the 20psi that stage 1 asks for.
I always thought that the stg2 was supposed to peak at around 21/2 psi?, like i say it may be worth asking kev as im sure he would be able to tell you/us exactly why this is...
I had m0rks old ECU with stg2 installed which was approx 2 years old maybe more, and there was a update to the map i was running. Maybe worth a trip to you revo dealer to see if there is a update to yours. Didnt cost me a penny and it was just somthing else to rule what caused my bad result.
I was talking about the requested sorry, if you look at yours, max requested is 17.4psi.
I will speak to Grant @ Westec to see if there is an update tho.
This is quite interesting, DPJ and GaryM running stage 2, theyre requested is a lot higher than ours.
http://www.seatcupra.net/forums/showpost.php?p=871187&postcount=10
http://www.seatcupra.net/forums/showpost.php?p=1243183&postcount=1
Both requested 21.xx psi at peak and just as much requested at 6k+ as what mine is asking for at peak power.
strange:confused::confused:, There has to be a simple`ish explenation as were running near on damit the same mods and getting pretty much the same results:confused:
certinatly would be nice to get some proper figures.
Would like to know if there is an update here too.
I've got a quick log from earlier.
Code:
	Group A:	'115
	TIME
	0.35	2200	21.8	1010	1020
	0.75	2200	33.1	1010	1020
	1.16	2240	71.4	1350	1060
	1.55	2320	93.2	1830	1290
	1.95	2400	114.3	2070	1610
	2.35	2520	131.6	2160	1890
	2.75	2680	145.9	2170	2130
	3.15	2840	160.9	2170	2350
	3.55	3000	173.7	2180	2500
	3.95	3160	182	2170	2540
	4.35	3360	188	2160	2540
	4.75	3560	185	2150	2540
	5.16	3680	182.7	2160	2540
	5.56	3880	182.7	2160	2520
	6.06	4080	176.7	2160	2450
	6.55	4280	171.4	2150	2410
	6.95	4400	168.4	2140	2320
	7.35	4560	165.4	2120	2270
	7.85	4720	161.7	2110	2200
	8.25	4840	159.4	2100	2160
	8.65	4960	156.4	2110	2120
	9.05	5080	154.1	2100	2080
	9.45	5160	150.4	2080	2060
	9.85	5280	148.1	2070	2040
	10.25	5360	145.9	2060	2020
	10.65	5440	142.9	2050	1990
	11.05	5560	139.8	2030	1980
	11.45	5640	138.3	2020	1940
	11.85	5720	137.6	2010	1930
	12.25	5800	138.3	1990	1930
	12.65	5880	136.8	1980	1910
Dave, i've been running HB9 since march on stage 2 and all my logs say the same, dopne various TBA's since then as well and it still shows the same requested boost above.
benny and daz above are showing the same figures on HB9.
I cant see going down a settings would increase the requested.
I've actually sold my SPS as i didnt think i'd need to drop the boost down for any reason unlike the timing which i do on lemmiwinks now.
ill get some logs done soon and get them up on stage 2 with hb9 timing 9 and fueling 8 i think had it done by revo garage rather than using a sps switch only had them turn up last week.
