Revo Stage 2 Logs
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Revo Stage 2 Logs - Down on power??
I would be really grateful for any/all comments on the following logs ......
Tuesday 7 February 2006 21:10:56
06A 906 032 HN 1.8L R4/5VT 0002
Group A: '003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC
/min g/s % °BTDC CF CF CF CF
1920 25.89 18 21.80 0 0 0 0
2080 30.67 18.4 21.80 0 0 0 0
2280 30.08 16.5 24.00 0 0 0 0
2480 57.56 85.9 17.30 0 0.8 4.5 3
2880 106.53 100 2.30 0 0.8 4.5 3
3280 124.75 100 1.50 0 0.8 3.8 3
3680 138.92 100 0.80 0 0.8 3 2.3
4080 151.08 100 0.80 0 0 2.3 1.5
4480 160.44 100 3.00 0 0 2.3 0
4880 164.47 100 3.00 0 0 1.5 0
5240 173.64 100 5.30 0 0 1.5 0
5600 179.39 100 9.00 0 0 1.5 0
5920 185.78 100 10.50 0 0 0.8 0
6200 186.36 100 12.80 0 0 0 0
6440 184.06 100 14.30 0 0 0 0
6480 9.44 7.5 11.30 0 0 0 0
5280 9.83 7.8 8.30 0 0 0 0
1640 17.47 12.9 19.50 0 0 0 0
1720 26.44 21.2 20.30 0 0 0 0
1880 37.11 98.4 15.00 0 3 0 3
2120 50.14 100 15.00 0 3 3 3
2360 72.5 100 9.00 0 3 3 2.3
2720 106.08 100 0.80 0 2.3 3 2.3
3080 119.25 100 0.80 0 2.3 2.3 1.5
3440 127.81 100 1.50 0 2.3 1.5 0.8
3800 140.08 100 3.00 0 0.8 0.8 0
4200 152.53 100 3.00 0 0 0 0
4520 161.56 100 4.50 0 0 0 0
4840 166.69 100 4.50 0 0 0 0
5120 171.14 100 6.80 0 0 0 0
5360 177.08 100 6.00 0 0 0 0
5640 180.69 100 9.00 0 0 0 0
5920 184.06 100 9.80 0 0 0 0
6120 185.19 100 10.50 0 0 0 0
6280 184.06 100 12.00 0 0 0 0
6480 185.78 100 12.80 0 0 0 0
6560 186.58 100 14.30 0 0 0 0
6720 185.19 100 13.50 0 0 0 0
5640 5.61 8.2 11.30 0 0 0 0
Group A: '031 Group B: '115
Lambda Factor Lambda Factor Engine Speed Engine Load Spec. Boost Actual Boost
700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar
/min % mbar mbar
1.343 1.000 1760 51.9 980 1010
0.969 1.000 1960 76.7 980 1160
1.016 1.000 2200 110.5 2170 1410
0.984 1.000 2520 145.9 2320 1850
1.008 1.000 2920 189.5 2400 2410
0.953 0.938 3360 191.7 2330 2370
0.844 0.852 3720 191.7 2300 2360
0.821 0.836 4160 191.7 2330 2340
0.828 0.836 4560 187.2 2240 2260
0.836 0.836 4880 180.5 2170 2170
0.821 0.836 5240 174.4 2120 2080
0.821 0.836 5560 169.9 2060 1980
0.828 0.836 5880 163.9 1990 1930
0.821 0.836 6160 157.1 1960 1900
0.828 0.836 6400 151.1 1930 1830
0.828 0.836 6640 145.1 1930 1830
0.821 0.836 6920 140.6 1940 1790
0.797 0.836 6280 9.8 980 1220
0.883 1.000 1680 84.2 1320 1150
0.992 1.000 1880 96.2 1350 1290
0.984 1.000 2080 109.8 1420 1420
0.992 1.000 2320 133.8 2230 1690
1.000 1.000 2640 170.7 2350 2170
0.977 0.961 3000 188.7 2420 2530
0.867 0.891 3360 191.7 2320 2380
0.836 0.836 3760 191.7 2310 2360
0.836 0.836 4080 191.7 2330 2330
0.836 0.836 4400 188.7 2280 2310
0.828 0.836 4720 182.7 2210 2190
0.828 0.836 5000 176.7 2140 2130
0.828 0.836 5280 175.2 2110 2060
0.828 0.836 5560 169.9 2080 2040
0.836 0.836 5800 165.4 2020 1980
0.828 0.836 5960 161.7 1960 1920
0.821 0.836 6200 155.6 1960 1900
0.828 0.836 6320 151.9 1950 1870
0.828 0.836 6480 148.1 1940 1850
0.828 0.836 6640 145.9 1940 1830
0.821 0.836 6760 142.9 1950 1840
0.828 0.836 6480 9.8 980 1590
0.813 1.000 5080 12.8 980 1080
Group A: '032 Group B: '118
Idle O2 Adapt Run O2 Adapt Engine Speed Air Temp In Boost Dut Cyc Actual Boost
-10.1 -10.1 700-6800 RPM <=110 C 0-100% <=1800 mbar
% % /min °C % mbar
0.6 -4.7 1800 34 0 1010
0.6 -4.7 1960 36 0 1090
0.6 -4.7 2120 36 0 1140
0.6 -4.7 2320 36 95.3 1340
0.6 -4.7 2640 37 95.3 1880
0.6 -4.7 3040 39 89 2460
0.6 -4.7 3480 39 84.7 2360
0.6 -4.7 3880 41 84.3 2360
0.6 -4.7 4280 44 84.3 2330
0.6 -4.7 4680 45 83.9 2250
0.6 -4.7 5040 48 85.9 2120
0.6 -4.7 5400 51 87.8 2060
0.6 -4.7 5760 54 93.3 1970
0.6 -4.7 6120 56 95.3 1910
0.6 -4.7 6360 58 95.3 1850
0.6 -4.7 6600 61 95.3 1820
0.6 -4.7 6840 63 95.3 1830
0.6 -4.7 7000 64 90.2 1820
0.6 -4.7 6640 63 0 1250
0.6 -4.7 1760 36 3.1 1070
0.6 -4.7 1840 36 5.1 1180
0.6 -4.7 2000 37 95.3 1260
0.6 -4.7 2240 37 95.3 1570
0.6 -4.7 2520 38 95.3 2000
0.6 -4.7 2840 39 87.5 2440
0.6 -4.7 3240 39 83.9 2450
0.6 -4.7 3560 40 83.1 2380
0.6 -4.7 3880 42 83.5 2360
0.6 -4.7 4160 45 83.1 2340
0.6 -4.7 4480 47 83.5 2290
0.6 -4.7 4760 49 83.1 2210
0.6 -4.7 5000 51 84.7 2130
0.6 -4.7 5320 54 86.3 2110
0.6 -4.7 5560 56 90.2 2040
0.6 -4.7 5800 58 94.9 1990
0.6 -4.7 6000 61 95.3 1950
0.6 -4.7 6200 63 95.3 1900
0.6 -4.7 6360 64 95.3 1900
0.6 -4.7 6440 66 95.3 1860
0.6 -4.7 6600 67 0 1940
0.6 -4.7 5400 60 0 1100
CFs look ok for now but bearing in mind when the weather warms up those figures will rise too...What timing and fuel are you running Dave?
Boost seems to be tracking ok, meeting and exceeding the requested until the arse end of the rev range.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Martyn said:
Does it feel down on power?
Can you log the intake temps? Maybe it's pulling back due to heatsoak?
Isn't intake temperature in Block 118 that I've logged above? :confused:
No, it doesn't feel down on power but you start to doubt the butt dyno after getting poor RR figures. :cry:
(Thanks for your time, BTW :cheers: )
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Martyn said:
Sorry Dave, missed that :(
The intakes creep up pretty quickly. I think you'd regain your lost power with an FMIC mate.
Take the RR figs with a pinch of salt bud :)
I know I should ideally have a FMIC...... It's an expensive fix if my problem is elsehere though....... What confuses me is that Saul, for instance with a very similar setup achieved far better results on Awesome's rollers........without a FMIC...
I can understand your point mate. Would be interesting to see the same blocks logged on Sauls car.
If you're not convinced it's because of heat soak i'd start checking the obvious like MAFs, hoses, exhaust leaks, N75 etc etc.
I'm sure someone more experienced will be able to cast more light on the situation though bud. I'm still fresh faced in the 1.8T :redface:
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
dave send me the logs in excel format (easier to read)
i log block 004 for charge temps
looking at them up there ^, theres some strange boost deviation but i cant make out at which RPM
boost duty cycle is n75, looks ok, 100 in that column means wastegate shut = boost leak
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Ok - Coops has kindly sold me his SP3 so I'll have that in a few days.
At the moment I'm still at a loss as to where to go, though:confused: . As my CFs seem low, I'd be looking to increase timing.......
Saul hasn't had a chance to get back to me yet. Would anyone else care to comment on my logs?
Pabs
5,936
Basingstoke
i wouldnt adjust your timing mate - I'm running boost 6 timing 6 (newer sps3) and mine is about the same as yours - I had it at timing 7 and although i recon it was slightly quicker, but the CF readings got quite a lot worse. Too much for the warmer weather, definately. Was seeing up to 8 on 1 cylinder, which isnt too good.
My car i think would benefit from FMIC - but its a lot of dosh for not much gain IMO... probably still do it though!
I've got a tad over 236bhp and 238lbft IIRC.
Wilko
Badge snob
Dave
Your maf values look OK
Your boost and N75 duty look OK
Your Timing advance and cf values look about right.
Your fuel trims are well within limits.
Your fueling looks bang on.
It doesn't look like there's anything wrong with your car.
I'd pull your plugs and take a look, and change them if there's anything wrong.
Ask someone with similar mods to do a 60-100mph in 4th and send you the time, and then compare it to yours. If there's more than a few 10's difference, you hava a problem.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Wilko said:
Dave
Thanks for that, John. :cheers:
Plugs new about 600 miles ago - but I'll have a look.
Saul & Pabs........ A visit to your private roads are needed! ;)
Pabs
5,936
Basingstoke
DPJ said:
:D If I put mine on the same Rollers as you did, I'd probably get the same. ;)
Then why are you worried about your power being down? How low is it compared to what you think it should be?
