revo stg 1 18 psi
cupra drew
full leather of course
May 28, 2008
273
cheshire/winsford
hi guys just fitted my boost gauge and am only peeking at 18 psi on revo stg 1 i thought it was supposed 2 be 21 psi is this anything to worry about
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
i dont know much on the revo side but might be few things.
some others revo stg 1 may only boost 18psi
how accurate is your gauge, where is it t'd from?
would doubt a boost leak but ya never know,
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
You can adjust your boost on REVO maps with a SPS mate. Its prob set to a medium setting.
Try asking in the REVO section.
Damoegan
Oct 15, 2007
8,993
Newcastle
No, sorry mate. I dont run REVO.
Like I said, post the question in the REVO section and someone will give you the right answer.
cupra drew
May 28, 2008
273
cheshire/winsford
heres the gauge
[/IMG]
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Revo settings for a standard`ish car are IIRC High Boost 6 Timing 6 - using the new SPS.
What mods do you have?
Idealy settings should be chaged in accordance with logging.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
With those mods if the settings are correct you should see ~21psi with stg1 - i did with near enough the same mods.
Either your settings are low or you have a leak, as Phil said proberly best to run a few logs on vag-com.
Danjw
My motors roughly the same spec as yours mate and im only seeing 18-19 psi on my autogauge. No problems with the car either, only had the boost gauge in for 2 weeks and i expected it to be running around 21psi aswell.
