Mine started doing something similar on the drive home tonight. When i engage the clutch while coming to a halt the revs dropped to just over 500 then picked up again. Every so often it does that while the clutch is still engaged or in neutral with the motor idling. Noticed that the idle speed is probably about 700rpm generally (just below halfway between 500 and 1000), normally it's around 800.
I know I need my throttle body cleaned and reset (this weekend's project), anyone reckon this is linked? The weather has taken a bad cold turn today, could that be affecting this? Coolant temp reached 90 (eventually, slow traffic) and stayed put there so not sure it's a coolant temp sensor fault...
