Revs freely at idle...?
Nov 10, 2004
1,000
Colchester, Essex
Hi folks,
Driving back from work today, I got home, parked up and noticed after reversing into my space the revs starting going a bit funny, not literally, because I wasnt laughing...:)think: ) but seemed to be going from 800rpm to 1200rpm in rapid succession.
Eventually about 10 seconds later it stopped and went back to normal.
I have Vag Com so I could go check it but I just wondered if that would pick anything like that up, especially if its a loose pipe or something, is it likely to be a spring in the DV (Forge 007P) needing to be changed?
Any ideas or should I just vag com it now?
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Noticed mine when starting has got a flexible idle at the moment, its doing the same thing. Will vag-com it, maf log it and judge from there... however mine only does it when starting after that its fine.
