revs when chaging gear
richy850
misses says that her car revs up a little when changing gears.
amy body any ideas ?
thanks
NickT
429
LB, Beds
Could be the clutch pedal switch packed up, mine has and it sounds like the engine revs 'hang a little' when I change gear.
Apparently the clutch pedal switch is supposed to cut the fueling/revs during gear changes as well as work with Cruise when fitted.
Here's a quote from Audiworld forum:
per the Bentley manual, the function of the Clutch Pedal Position switch (aka Clutch Vacuum Vent Valve Switch):
This signal is used to avoid RPM over-oscillation and load change impacts when changing gears and is also used for the cruise control system.
richy850
ok have to look tomo its realy bad when u give it a bit ....
richy850
can some one take a pic of where this clutch switch is for me ?
adam_lincs
DJ Extrodinaire...
Aug 27, 2010
106
lincs
my mum always revs when changing gear and also when setting off in 1st - it aint no clutch switch tho i tell ya!! lol
richy850
found switch easy didn't have to take any of underdash out.. switch is stuck in so order a new one £10.47 + vat will fit tomo
richy850
no m8 i didnt but the switch was just pushed in and was very stiff to pull out so ordered new one
