Jun 5, 2008
511
Leeds
Hi guys finally got the Rns 510 installed and it is great, one problem i have found is the Aux in. When i connect something i get a lot of static noise through the speakers, i remember reading somewhere that you need to change the wiring possibly but icant for the life of me remember where, anyone had this issue and knows how to fix it???
Chris
Chris, did you ever get a response to this ?
I had this problem a year ago and eventually posted a solution on DanGB's retro fitting guide for the Sat-nav. Here is the text I posted then...
AUX connector with MFD3 (RNS510)
Quote: Originally Posted by DanGB
2. The ground connection for the AUX may be in a differnt place in the MFD rather than your old headunit. Both should have a picture with the connections on, so compare where the AUX connections are. Unquote.
This info maybe elsewhere on the forum, but I've sorted out the normal AUX socket (simple plug with plastic cover in the console between the front seats) connection on my MFD3, with the help of NickP, and it seems appropriate to record it on this thread.
On the original Seat CD/Radio the AUX cables (3 off - black earth, white and purple Left & Right feeds - can't remember which was which) were connected to the CD earth/L/R pins at the back of the unit, as identified from the pin out sticker on the back of CD/Radio unit.
For the MFD3 these three cables need to be moved to the respective AUX pins as identified on the pin out sticker on the back of the RNS510. Same blue connector block, just different pins - in fact the black earth pin is already in the correct position as the CD earth on the CD/Radio unit is now the AUX earth on the MFD3. Threrfore only the L & R feeds need to be moved to new pins, so move the L feed to the AUX L pin and the R feed to the AUX R pin, as identified on the RNS510 sticker.
I don't have a diagram of these pin confirgurations, but if you compare the two pin out stickers it will all be clear.
To move the cable pins around in the blue connector block firstly release the blue connector from the main quad block connector then remove the outer blue sleeve by lifting the retaining tab on the side (a fingernail will do the job) and sliding the sleeve away from the black connector block beneath. Then select the cable pin you want to remove from the black block and press down gently (with a small screwdriver or ballpoint pen) on the lower of the two silver recesses at the pin position, and it should just unclip and slide out from the connector block. Move the pin to the new position on the block and slide down until it clicks home securely.
Then reassemble the blue connector and quad lock block and refit to the RNS510. The AUX socket between the seats should now be back to good sound quality at a normal volume level.
The above was an easy fox and only took me half an hour.
Ian
yes i got it sorted thanks, just looked at the diagram on the sat nav and managed to figure it out!!! Bit of pain especially as when i come to sell the car i am going to take the nav out. I am trying to get a proper ipod lead now for the sat nav but dont want to pay the £200 it costs for the vw mdi
You and me both, I have an iphone and want to be able to connect so that i can play podcasts etc or my digital radio from it and be able to see the track information. I might have a look at an aftermarket option which would be less than a £100 hopefully. Cheapest I have seen the MDI is about £125 and then you have to pay £20 for the ipod cable which a bit of a rip off imo!
