rns 510 fitting
Kasam1994
Kasam1994
Sep 12, 2016
20
Nottingham
Hi I'm trying to fit the vw rns 510 in my leon fr 2008 but it doesn't fit in properly anybody which bit of plastic I need to cut off:confused:
RD-Woo
the Grave Digger
Nov 8, 2016
77
Yes, if the unit comes from the vw model's you will need to cut the middle plastic from the dash board because
this unit have SD-card port and it will hit that plastic..
Same procedure if the RCD-510 is fitted, mate
itsmeagain
158
Birmingham
Its easy to fit, just cut out the piece of console that its catching on. Mine took about 10 minutes to do. Then the Unit will slide in no worries.
cupra_ahhh
1,203
11
Tonbridge, Kent
Yeah I had to do this for my RCD510, I bought myself a little dremel-like tool kit from Maplins to get into the small space.
As an FYI, I placed a couple baby-wipes under that piece of plastic that you need to remove to catch all the dust and plastic bits, makes tidying up a a lot easier.
Kasam1994
Kasam1994
Sep 12, 2016
20
Nottingham
Cars at the garage atm due to my cat converter snapping in half :( as soon as it's back I'll upload pics if it let's me
Sent from my SM-G935F using Tapatalk
Kasam1994
Kasam1994
Sep 12, 2016
20
Nottingham
Hi Kasam
I am thinking of doing this any fitted pics? :)
