Rns 510
itsmeagain
158
Birmingham
When you fit an VW RNS 510 does it need coding to the car, it works perfectly. Just when i scanned my car with VCDS a few codes came up regarding the infotainment system
3 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 11
Reset counter: 200
Mileage: 53200 km
Time Indication: 0
Date: 2000.00.00
Time: 15:50:55
01304 - Radio
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 200
Mileage: 53200 km
Time Indication: 0
Date: 2000.00.00
Time: 15:50:55
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 160
Mileage: 53200 km
Time Indication: 0
Date: 2000.00.00
Time: 17:08:28
Kasam1994
Kasam1994
Sep 12, 2016
20
Nottingham
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 200
Mileage: 53200 km
Time Indication: 0
Date: 2000.00.00
Time: 15:50:55
01304 - Radio
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 200
Mileage: 53200 km
Time Indication: 0
Date: 2000.00.00
Time: 15:50:55
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 160
Mileage: 53200 km
Time Indication: 0
Date: 2000.00.00
Time: 17:08:28
I put it in my 2008 FR it's a straight fit everything works fine but if you have the large mfd you will need to code it in order to get sat nav directions on the mfd but if your not really bothered about that it's a straight fit
Sent from my SM-G935F using Tapatalk
Sep 10, 2011
1,480
cheshire
Hi, do you suffer from battery drain mate
Sep 10, 2011
1,480
cheshire
Yeh mine is a 2008, this is the firmware I think
Sep 10, 2011
1,480
cheshire
I already have a disc with it on somewhere I'm sure from my previous car also the disc to enable the DVD in motion
Sep 10, 2011
1,480
cheshire
Also forgot to mention my car has a parrot kit fitted will affect fitting the rns-510?
