Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
engine bay looks amazing Rob. What's the Carbon Seat Sport bit where your battery was?
back feed thru the rear washer supply
Quite easy yes. All I did was connect the front washer pipe to the rear feed in the engine bay (they just push together right where the bottle was), split the join in the boot and connect the front to the rear feed from the bay, and the rear to the rear pipe in the boot - simple. I only needed to run 2 wires for the pump to the boot, I put a resistor on the level sensor as that's not important for washer fluid IMO.
330ohm, 10-watt Resistors on the EVAP and coolant level sensors too, so no warning lights or faults.
I had thought about removing the coolant reservoir altogether, as shown in this thread, but decided I'd go a different route and downsize it but still retain a small tank. Removing the coolant tank - http://forums.vwvortex.com/zerothread?id=3397495
Whens the turbo going in to CR Rob?
Would be interested to hear how you found dealing with them aswell as I'm thinking about sending the KO4 to them to play with along with a few other people
