Hehe result!
I thought you had a vacuum manifold setup before Rob?![]()
I also picked up a 42DD vacuum manifold kit from Awesome
Cool! (I love pun)A good example on my car - at Crail on the start line, outside temp was 22 degrees C, intake temp was 26 degrees (as displayed on the Scangauge II). By the end of the 1/4 mile after a full power run the intake temp was 19 degrees!![]()
Only did 2 runs, having never done the 1/4 mile before. Did a 15.3 then a 14.8 on the 2 runs then called it quits as my brakes were causing problems.
After only 50 miles with the new Tarox and Pagid pads, the brakes are already feeling good, strong bite at most speeds now, no rubbing. The discs looks cleaner, shinier and better swept than with the yellowstuff pads. Overall I am happy with the new pads.
