Sorry should have said it is at the bottom of the plastic trim between the rear window and the door. had an independant engineer out to it and it turns out the plastic trim is rubbing the paintwork and it has started a little bit on the passenger side. He seems to think other
ibiza's may be doing it as well. It was hard to spot on passenger side but if you eased up the trim it was visible.
