Rust/Corrosion on Ibiza FR Door Frame
ant5735
Has anyone else had rust starting to appear at the bottom of the plastic door trim? Will put up pics when i get enough posts to do it!
platofan
218
I had a little on the door sill. Just got the primer and touch up pen on it.
ant5735
Sorry should have said it is at the bottom of the plastic trim between the rear window and the door. had an independant engineer out to it and it turns out the plastic trim is rubbing the paintwork and it has started a little bit on the passenger side. He seems to think other ibiza's may be doing it as well. It was hard to spot on passenger side but if you eased up the trim it was visible.
