Samcos...
Nov 2, 2004
9,334
South Wales
Well i just thought i'd show you a few pics of what i'm doin. Slowly building up the hoses to replace the majority of the normal ones.
Comin along ok. If anyone needs any more pics or help or anything let me know.
Before today...
http://img.photobucket.com/albums/v147/philwarren11/Cupra/DSC03735.jpg
Finished...
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
looks really good Phil! thats what i would like to do but im a speed freek and want to spend every penny on going faster :D
What is the description (sizes, angle etc) of the Air filter to MAF pipe? I need one of them?
HoocH
flashbsd
nice one, what size/cost were the coolant ones from the bottle? and the fuel lines to the FPR?
Nov 2, 2004
9,334
South Wales
Thanks for the comments!
The elbow is...70mm bore 45 degree elbow E45-70 part no. from samco. Its helped a lot of with the actual location of the dynatwist since i fitted the golf tip.
8mm ID for the coolant and the fpr is the same as the vac hoses, 3 or 4mm ID. I used 3mm.
I cant really give away prices coz i know a few people who work for samco. But please dont ask me to get you any coz i cant, i have tired!!! lol.
h17och
Sep 1, 2005
3,504
Dunstabubble
Thast y i want one, my dynatwist isnt in a great place since fitting the TIP!
cheers phill, your a star :cheers:
Nov 2, 2004
9,334
South Wales
acidstrato said:
Phil could u tell me wot pipe is used on the top of the I/C pipe which normally goes to dv but u got he relocation kit
The one i've blanked off is a 22mm pipe. Its a bit tight tho, if i was doin it again i would use 25mm. Same as the rest of the DV relocation kit.
I've made the photos bigger so hit F5 if you wanna see them better.
I'm also goin to replace a lot more coolant hoses when i get the next order through, keep you posted on that. I got a load of spare 19mm hose, which i'm using to replace the breather that normally fits onto the original airbox, stupid plastic corrugated tube thing. That should look good coz then you can see the shiny breather on the end.
Deleted member 9043
looks verry good man!
coold you also tel what kind of samco u use for on the throttle body?
diameter and the angle downwards?
next step polish some parts maybe?
grtz
Nov 2, 2004
9,334
South Wales
jambojones10 said:
Can you use 8mm Vacuum tubing for the coolant hoses? or do you need something more reinforced
I dont think you can coz of the temp of the coolant, maybe find out what temps the vac hose can hold.
Today 18:13
ibi-turbo looks verry good man!
grtz
I got a feeling its 70mm, it came with the forge fmic kit, i will be changin these very soon so i'll let you know.
Polish parts next yep, inlet manifold, strut brace and possibly the whole rocker cover and some more caps etc...
Forbez
Huge Member!
Feb 11, 2004
5,877
S.Wales
Phil you couldn't claim that you've mislaid your TIP could you??
Looking wicked Phil, im slowly working towards the same! (Very Slowly!!!)
h17och
Sep 1, 2005
3,504
Dunstabubble
Looks like boost guage!! should have jumped into the pipe from inlet mani to brake servo(where the green blank off if in the pic) (bottom left)
HoocH
