Alhambra Lover
I have a seat Alhambra 2002, had it regassed yesterday, it has made it slightly better but not very cold all. I plugged it into diagnostics and it come up with a fault code.
01184 Rear Vent Outlet Temperature Sensor (G174) Open Circuit/Short With Power
I have searched the Internet for hours to find the location of this sensor and to see if anyone has had any similar problems and can't seem to find a thing.
Anyone have any ideas, would be greatly appreciated?
Sensor is located behind the small removable panel on left side of boot (above the two power outlets). Pull plug connector off sensor and turn sensor 90 degrees to remove.
Thank you very much for your help, has been a pain to find it. Do you have any idea what resistance reading it should give?
