dalyoftelford
8
Hi my project altea is starting to get me down, after being kept inside during the work so far it was parked outside last night , after heavy rain the drivers seat and rear floor is soaking wet !!! Any ideas where and how the water might ge getting in ??
Paul
Sent from my SM-G900F using Tapatalk
The only thing I can think is the door seals and the window seals? Other than this I can't see where it is coming from??
Have you looked underneath for any rust?
Stupid as it may sound, was the window open?!
Were any of the other seats wet? Was the front drivers floor wet through as well? If not, are you sure that the window was completely up and home?!
Have you tried sitting in it and dousing it with water? Did you find anything then? If not, are you sure someone didn't open the window?
I would try and replicate the problem using a hose pipe, but make sure your windows are completely shut
Hi , I took the car to the fire station and we put the smoke machine in it and sealed all doors and windows, so I thought it was fixed but been out today a d it's damp again
Check the scuttle drains
At the base of the windscreen on either side a lot of leaf litter builds up blocks the rubber drains and rainwater then finds its way into the car.
Lift the bonnet and fish out all the rubbish at the base of the bonnet hinges and that will probably be the answer.
I'm surprised the drivers seat is getting wet that would point to something dripping down from above and I can't imagine you wouldn't notice a hole in the roof. Have you stripped the carpet back and checked the floor pan?
