Seat belt Removal and Changing
Jul 11, 2009
643
Dorking
it's simple enough to remove the belts. The problems are; the seat belt chime needs turning off, the side air bags plugs need resistors fitted, and as the front belts plug in, that issue needs resolving to avoid the airbag light staying on. Space for race seats is very tight, new belt anchorage points need to be made for the inner front and a bar at the rear. My seats are fixed and do not adjust, this saves weight and cost. The weight saving is massive and is the main reason my car is so quick on the 1/4 mile.
azizfares
183
Beirut, Lebanon
That's a massive turn around man, hats off ! But i am just interested in changing the seat belts to red.
Kibby
450
39
Belfast
Would have been cheaper to get them from the start go to your local dealers and ask them to order some they can do it
Sent from my LG-H815 using Tapatalk
Kibby
450
39
Belfast
Aye I payed extra for mine but mine is the FR Black edition they may be able to order them for other versions
AdamO'C
64
Teesside
Ahh right hmm I'm wondering if they're available for older models then, I know the shape hasn't changed that much so they may still fit
Kibby
450
39
Belfast
No they will fit the belt harness is the same just ask can you order them shouldn't be a problem
devJORD
OBD11 Wizard
Nov 14, 2014
387
Hi mate, I'm keen to retro fit the red belts in mine too however I'm not sure if it's worth it. Could you post a picture of yours for me so I can see what they look like with the seats? I'm thinking they would look alright, but I want to be sure.
Cheers.
Kibby
450
39
Belfast
AdamO'C
64
Teesside
I rang tehe stealers yesterday and they said that they don't know if they will go straight into mine cause it's an 11plate so he said he'd find out and let me know, still waiting on him haha
AdamO'C
64
Teesside
Good news I found out that the seatbelts should fit according to the mechanics in the workshop and I also found out how much it's going to be to buy the set... For the front it is £232 per side, £98 per side for the rear L/R and £160 for the rear middle so it's a grand total of £820
