Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
By the way, how do you know its compressor surge?
Get reid of the Forge BOV and see what happens. It has no benefit over the OEM Rev D recirc valve anyway.
Sorry, I just remembered does the Cupras have a electric actuator. And the turbo on this car is this K03s?
whats the difference between k04 and k03? if the k04 is bigger doesnt that make more turbo lag? also what sort of power do you get with the k03 and the k04?
Hi there robdf2, I am interested in your catch can. Do you have all these parts for this? Thanx! And how long can I aspect it to arrive?
A. PCV Nipple 1. 3/32 Allen Wrench
B. PCV Guidance Block 2. ¼ Allen Wrench
C. Manifold Block Off Plug 3. T25 Torx
D. 3 Set screws for Block Off Plug 4. T30 Torx
4. 17mm Wrench
E. One O-Ring for Block Off Plug 5. Adjustable Wrench
F. One O-Ring for the PCV Nipple 6. Flat Head Screw Driver
G. Catch Can 7. Blue Loctite
H. Lines
I. Three clamps
J. Three 90 degree fittings
K. One Drain Valve
L. Catch Can Bracket
M. One adell clamp
N. One allen head screw with matching lock nut.![]()
sorry mate sold
i need to update my sig![]()
Thats not actually compressor surge. Compressor surge would only be heard when your ON the throttle, not after you let off.
