Hi all.
I'm have a problem with a car I have just bought? When the car gets up to temp the oil light will start to flash and I will hear the buzzing noise but this ONLY happens between 1800 and 2000 revs. When it comes on if I let go of the throttle and let it idle it goes off, if I rev it past 2000 it goes off it only comes on between the two but it does go off.
I was wondering what it could be.
I was thinking wrong grade oil or oil pressure switch.
It does have a oil leak but I can't see that causing it or are these cars a bit fragile in that respect?
No engine knocking or tapping
Runs absolutely fine
It has done 114000 miles
Thanks for your help
James
James
