Seat Ibiza 1.9 tdi 130 pd engine
Steven20151
25
Hi looking for some help please bought a seat Ibiza 1.9 tdi 130 got the pd engine do in bought the car the other nyt and the seller was saying the fuel gauge wasn't working was a common fault and easy fix so I bought the car stupid me! And took the clocks out to see if I could see if there was a problem I noticed where the fule guage is at the back look like it was bit burned like the solder came away so I put a bit of copper cable in there see if that fixed it but a bit of smoke came out of the panel now I don't have any dash board lights and when I try to start it it starts for couple seconds then cuts out. Can I buy new clocks from scrap yard and put them in? Can't find any that has the voltage meter clock with the oil temp clock anywhere in the scrap yard can someone help me please thanks in advance its a 03plate
britishsligean
341
Ireland
You can buy them from a scrapyard but a seat service centre has to install it as the new instrument cluster needs to be synced with the car
Steven20151
25
Hi thanks for the reply I got clocks from a seat Ibiza 57 plate tdi but they don't have the oil or battery dial on them can they be used if I take them to a seat garage ?
Steven20151
25
Hi don't know it only had 5 gears if that helps? But was a tdi a car symbol is showing up with a key flashing
