psykota
hi
I'm new here
I have a seat ibiza 1lt from 1998
can anyone tell me tthe place of relay 72?
and _I have another problem
I don´t have speed, temperature, fuel indication and no clock too
I have verified all fuse and they are ok
can you help me?
thanks
hi
I'm new here
can you help me?
thanks
Have you checked all connection, or the connection block on the rear of the speedo. That MIGHT be the case - because they can come loose. Do the warning lights come on on ignition or not? I'm no mechanic, but I have fiddled around quite a lot with my car by now so... ;)
thank you for your replay
yes I have warning lights and I have also the dimm light (instruments ilumination).
I have indication of turning and heading lights.
no, none
does the input signals (temp, speed, fuel level ) came all together in a same connector?
and what about the clock? it doesn't has input signal. i think! its strange...
hmm yeah it's just one connector block on the rear of the clocks. Have you checked it ye? Sounds like a faulty unit you know... might be an idea to buy a new one or something. Do you know your mileage? That comes up does it? Strange... must be a fault within the unit you know *-)
