Not sure if this counts as a mod :D
But hopefully this does (stole the idea from Ollie1990 (hope you don't mind))
And finally... 5 hours washing n cleaning... ready for the rain!!!
Wheel alignment - again!
And new set of front tyres :D
Car looking great, I believe the particular african american small wheels will be amazing. Excellent electric power far too.
Just a couple of small tweaks to add. Fitted aftermarket TPMS:
Also modified settings to add needle sweep and finally mph, cause the MFD was driving me nuts in kmph:
P!ssing it down ... but... LEDs:
Old DRL:
New DRL:
Old Sidelight:
New Sidelight:
Front at night:
loking good. i'm picking up my Supercopa 2012 version this saturday and can't wait.
Take it you used vag.com to add the needle sweep and change kmph into mph. If so do you have the vag.com codes for both? as these are two things I want to do straight away to mine!
Thanks Matt
Thanks Matt
Cheers. Nice, I'm sure you going to love it!
I actually used an app called Carista which is basically a front end for the popular vagcom options.
http://www.caristaapp.com/customizations/?car=seat_leon_2011
Yes, my wheels do need a clean.. and my "FR" vinyl decals aren't applied yet cause the paint wasn't dry enough (and it hasn't stopped raining).
Reactions: Lottie Davies’x
That looks good thanks. What would I need to use with this to enable things? Do I need a certain lead?
http://www.amazon.co.uk/Carista-Adapter-iPhone-iPad-Android/dp/B00YVHGTBM/ref=sr_1_1?ie=UTF8&qid=1452168103&sr=8-1&keywords=carista
This is what I use... it connects via Bluetooth to any android/apple phone/tablet. Keep in mind that on iPhone it only works with Carista App. But on Android you can use it with other apps (I use it with Torque Pro).
Looks fab mate!
Cheers :D
Thanks for the link. will have a proper look into it when home.
How difficult did you find it to use?
It's pretty simple... if I remember correctly you get a main menu where you can change settings or scan for fault codes. You then just pick a category and it shows you a list of things you can change along with the currently selected option. Took me more time reading down the list of options cause theres loads.
The reader itself just plugs into the ODB port. Don't think engine needs to be on. Think it has red light for power and flashing white light for communication. You then just pair it like any other bluetooth device.
If your getting a supercopa you won't get needle sweep.
I have tried on mine turns out they have a version of the dash that doesn't do needle sweep
Ahhh poo! oh well its something i can live without. would have been nice but still. thanks for giving me the heads up SMC83.
I'm hoping as its the supercopa edition that i can at least change the digital readout from kmph to mph. i'd end up probably using that more than the guage.
