VSSZZZ5FZER is vin Please help
328197 - Motor for Right Temperature Flap
B108D 54 [00001001] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 181388 km
Date: 2025.10.05
Time: 22:42:05
Voltage terminal 30: 11.4 V
Outside temperature: 11.5 C
Inside temperature: 22.9 C
Right temperature flap: actual value: 0.0 %
Right temperature flap: actual value: 248
Temperature door right - Specified value: 238
787211 - Windshield Washer Pump
B1261 13 [00001000] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 192
Mileage: 183340 km
Date: 2025.12.11
Time: 15:27:08
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: g ltiges Funktelegramm
Voltage: 14.7 V
Outside temperature: 5.0 C
787212 - Windshield Washer Pump
B1261 01 [00001000] - Electrical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 185
Mileage: 183511 km
Date: 2026.01.03
Time: 21:42:16
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.5 V
Outside temperature: -1.0 C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 181388 km
Date: 2025.10.05
Time: 22:42:05
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 192
Mileage: 183340 km
Date: 2025.12.11
Time: 15:27:08
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.7 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 185
Mileage: 183511 km
Date: 2026.01.03
Time: 21:42:16
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.5 V
