Just got the butyl tape a few days ago. Going to attempt it in a bit today. Just a few questions
Once ive removed the metal plate do I feed the strip In the ridge bit all around then close it and tighten do I need to put it all around the sides too Once its back in place ?
Also last time I was having trouble removing the rear door cards. My car has the manual roll down mechanism does anyone know how to take them off ?
Thanks !
Take the metal accessories carrier off (you need to tape the window in place and loosen the glass clamp bolts to do this). Clean all the old sealant off of the door and the accessories carrier. Put the butyl tape in the ridge where the old sealant was and refit. You put it all around the bottom and the sides. No need to do the top.
There is a FAQ section on here and this is in there, everything you need to know is in the link in the FAQ
There might be 80 odd pages on the topic but all you need to know is there so no need to post up a new topic about it, can be easily found on a search as well
I don't have plenty of time on my hands and found this within a minute
http://www.seatcupra.net/forums/showthread.php?p=3255713#post3255713
:rolleyes:
Your welcome
Well done you!
Consider that not everybody is so adept at searching as you are, and that the nature of the forum is that it's a place to gain advice, experience and give the same. No need to be obnoxious, especially when you've only been here 5 minutes yourself.
Why thank you!
And I'm not good on a computer either but I still found it pretty easy on a search, I mean thats what its there for
Not sure why me being here for 5 mins has got anything to do with it, I've gained advice and given it and searched for it, all in my 5 mins :rolleyes:
With all your wealth of experience you could've posted the link up yourself rather than typing it out which isn't easy for everyone to get the hang of as most would rather see it, so pictures that someone has gone through the effort of doing for this very reason...
Save it for someone else
