Sensible drop on coilovers
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Im thinking of going for FK coilovers in Feb some time, what would be a recomended safe drop?
i want to lower the front 30mmish and the back say 50mmish?
Will this cause any major problems or could i go lower?
Thanks for your help
Adam
andy_gdon
494
Ill let you know in a week or two!!
i have my FK's on order. 30mm isnt possible on FKs...the highest they go is 45mm.
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Surely if you go that low, you'll have probs with the Camber being out on the front, therefore eating tyres, also Isn't there problems with ARB's and driveshafts if you go lower than 45mm???
I really want coilovers but i don't want to do any damage to anything else, therefore - sensible!!!
andy_gdon
494
There is a local guy with a FR on KW's that has his done more than 50mm with no problems!!
Only one way to find out though :D
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
i suppose so, you never know till you find out,
How come the highest you can go on FK's is 45mm?
Fingers crossed 45mm won't cause problems
EdButler
713
Sheffield
Youll probably get some rubbing with 17's on the fronts with a 50mm drop and 205/40 profile tyres (i do woo!). This only occurrs when going over large and fast bumps or cornering at insane speeds.
Stock 16's i could get away with (just).
Rears are fine at 50, mine seems to look just right with that drop but some ppl say a little more. All i can say is subs and extra people and you may end up regrettin it :p
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Ed, have you got any pics of your car lowered 50mm?
I rang up rimstyle and they said the approved lowering range is 45mm to 85mm,
but 40mm should be possible,
Ed, Can you still get 5 people in the car easily with it down 50mm and have you had any problems with it that low?
Cheers mate
EdButler
713
Sheffield
Sisson: Theres some snaps of my car on this thread, totally unloaded:
http://www.seatcupra.net/forums/showthread.php?t=75571
Had 4 burly blokes in once and it was hella low :cartman: Mike_OBD got a pic so ill see if he still has it. Should be ok with a little more but dont know how much room in the arch there was spare (prob plenty if your offset is hi and your wheels are fully under). The fronts didnt rub any more than usual either iirc.
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
That picture looks spot on, just what im after,
have you had any probs with tyre wear or ARB's being that low??
Cheers mate
EdButler
713
Sheffield
The suspension on mine has been on for around 25k. The only problem is that the ARB hits on the wishbone at 95% to full lock. You can sometimes hear it clang a little if the wishbone bushes move. I had all this checked out at JBS and its negligible damage (just scaratching).
HOWEVER - DO NOT reverse off a Kerb or large bump/dip at anywhere near full lock. When the car is briefly in the air the ARB can move underneath the wishbone and then clang back into its previous position. Did this once and it made a horrible noise and was lucky (i guess) for nothing to break. Other than that its all dandy!
Commence knocking on wood :p
I bought the car with some Eagle F1 GSD3's with 2mm all round and not a touch of uneven wear. Camber and toe seems perfect altho ride quality is harsh and watch those alloys when going over bumps! Theres such little give that the tyres take lots of abuse.
I see your in Derbyshire! Why not head over next Sat to sheffield if you can, might let u have a play in mine ;)
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Just sorted a decent price out with JBS for fitting coilovers and 312mm brakes
I should hopefully get it done at the start of March
Thanks for all the replies and tips, even tho my wallet is taking a beating!!!!!!
Cheers mate, will be in touch about meets once iv had it done
andy_gdon
494
Ill have my pics up in about 1-2weeks-car is having abit of a make over!!!
Fk Silverline X's wound down to the max being one such thing on the list!!
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Would it be advisable to replace the top strut mounts when i have the coilovers fitted?
My cars nearly done 30k
Adam
