Steerpike
24
Hello,
I bought a used Seat Leon Diesel (04) a year ago at 43627 miles. I'm not sure on the recommended timespans between minor and major services? It's now got 56000 on the clock a year later. I think the last full service was when I bought it 1 year ago. Does this indicate a full service is required? Sorry to be a bit thick! I will only book a minor service if I can as funds are a bit tight. (What is the approx damage for a full service anyhow?)
Cheers!
Check the manual ;)
From memory it's something like minor service every 10k then major one every 20k (give or take a few k)
That's for a 1.9tdi (non pd)
Full service on my Cupra R is £400, interim is £200, so I would expect around the £350 mark (from a SEAT dealer, anyway)
Hope this helps
Alex
Depending on what needs doing for my tdi it's around £100 for interim and £200 - £400 for full service (depending if belts etc. need doing).
That's from local Vag specialist though and not SEAT (they quoted me £500 for my interim and saying could be up to £800 for my full service!!! Some SEAT dealers may be resonable, but not all so be aware!!!)
Brief summary of service schedule:
Oil change service every 10K
- change oil and filter
- check brake pads and disks
Full service every 20K or 12 months, whichever comes first
- change pollen filter
+ check lights, tyres, wipers, "fan belt", toothed belt, steering, driveshaft gaiters
+ levels in gearbox, coolant, hydraulic fluid, power steering, 4wd, screenwasher
Vehicle exterior
- Door retaining straps: grease and lubricate locking pins
- Sun roof: clean and lubricate guides
Not in service schedule but worth doing - lubricate bonnet lock.
Additional items
every 40K,
- change spark plugs (petrol engines)
- change air filter
- change fuel filter (diesel engines)
every 40K or two years
4WD cars, Haldex clutch
every 2 years
- change hydraulic fluid
every 60K or 5 years
- change toothed belt (diesel engines)
every 120K
- change toothed belt (petrol engines) (This may have been revised down recently)
