Should XL tyres have different pressure?
nog
91
Shropshire
My new tyres are 94w instead of the originals which were 91w.
Should they still be inflated to the same pressure as before (ie as per info in fuel cap) or do the stiffer sidewalls require more/less pressure?
I just dunno :think:
nog
91
Shropshire
Cheers fellas, I'll leave them as they are then. They seem 'wobblier' than my old tyres so thought I might have them set wrong.
AlexC
I'm fitting a new set of tyres tomorrow. If any of you know of anyone in the market for a set of 225,40,r18's lots of tread left. Open to offers
G.P
1,281
45
Worcestershire
Presuming they are of the same brand, could be tread block movement as you now have more tread to move around..
AndyG_TSi
1,174
East Manchester
XL Rated tyres are designed for heavy cars, rather than for carrying 'heavy loads' EG some vehicles designed to carry more than 5 people & some estate cars may have XL rated tyres fitted as standard.
an XL rated tyre will achieve its maximum load bearing capacity at a higher PSI than a 'normal' tyre
In other words, if you had 2 identical tyres, 1 was XL rated and one wasn't, the 'normal' rated tyre might achieve its 'optimum' load bearing performance at 'say' 35 PSI, whereas the XL rates tyre would achieve its 'optimum' load bearing performance (or identical performance as the normal tyre) at 45 PSI
So YES an XL tyre should be inflated to a higher PSI
If you inflated an XL rated tyre to the same PSI as a non XL tyre, then the XL tyre would actually have a lower load capacity than the non XL tyre
Found this;
"Extra Load tyres are designed to be used at higher pressures than normal tyres. They have the same maximum load capacity as a normal tyre with the same Load Index but achieve this at a higher pressure. Normal tyres are inflated to pressures between 2 bar and 2.5 bar. They reach the maximum load capacity as specified by the Load Index when inflated to 2.5 bar (35psi) Eg for a Load Index of 94 this is 670kg. Extra Load tyres can be inflated to pressures up to 2.9 bar (41psi) and actually have a lower load capacity at the same pressure as a normal tyre with the same Load Index. To get the 670kg load capacity for a Load Index of 94, an Extra Load tyre must be inflated to 2.9 bar. At 2.5bar it will only have a load capacity of 595kg.
nog
91
Shropshire
Interesting, a difference of opinion then. Not sure what to do now.
Might try them a bit higher (36 instead of 32 at the front, 33 instead of 29 at the back) and see how it goes.
Anyone got any experience of 225/45/17 94w on a 2.0 tdi?
nog
91
Shropshire
Ok I'll have a fiddle tomorrow and see how it looks. Ta mate. Any maths behind the figure of 40 or just punt?
AndyG_TSi
1,174
East Manchester
Read my last paragraph in my initial post.....2.9 bar is 41psi, but I just said 40 for the sake of an even number lol
that figure is, of couse if you need the tyre to be pumped up enough to reach its max load bearing capacity, if not you csn have it set less
I notice in your initial post that the original tyres had a load index of 91, which is a load capacity of 615Kg (1230kg accross an axle)
So you could go less, say 37psi all round.....just see how it feels once you do it
nog
91
Shropshire
Thanks andy, last question I think - would you not have higher pressure at the front as per original numbers?
richicupra
1,823
9
my fronts are at 41PSI as stock
Judging by your avatar though you have the 19" wheels which are inflated to much higher pressure than the 17 or 18" ones.
OP: Stick to what the petrol cap says, running at too high pressure = less grip and wearing out the centre of the tyre tread very quickly.
G.P
1,281
45
Worcestershire
Yes the fronts should have 2-3 psi more in them, as indicated in the fuel filler.
I run my 2.0tdi on XL tyres at 33 front/30 rear..
