dare to be different
8x17 Comp CXR's ET28
245-35-17 rubber (in picture) also running 225-45-17 & 235-40-17 rubber on other rims.
Wat offset are those wheels?...and tyre size?, how much have u lowered it and does it rub?:whistle:
The wheels are et37 with a 15mm spacer each side on the rear. The fronts now have a 5mm spacer to accommodate the brembos. Tyres are 205/40/17 Yoko Paradas.
Its lowered about 60mm all round i think. I need to measure a standard cupra.
It rubs on the rear over massive bumps and the fronts sometimes when cornering too hard where the road is bumpy. I just need to roll the arches a bit more.
will take some of mine when i get a chance.... a good day when its not raining, 17" rs4's lowered on coilies:p
Russ did you fit spacers with your force 10's? they look smart!!
just gotta set on order :)
