The 5 smd ones make sure tou order the canbus ones and orange :)
I didnt try with a normal non canbus one i just guessed that they need to be, i have changed all indicators to led and not had an issue!
Coolio....so it has the plastic base on it with the two wires as the connection. I might make an LED indicator myself using the indicator case and resoldering the SMD's in a row. I know you can buy the side indicators like this but they are not canbus....then again it may be easier just to buy a resistor for the other style of indicators...but what sort of resistor?!?!?!
How easy/difficult is it to replace the side repeaters? Got myself a set of smoked ones.
Very easy mate, a good way to do it is to use a normal bread knife in a sock (so you dont scratch paint work) in one side an they just pop out. Takes 20 secs
