nige1976
hi
quite a large gap has appeared between the top of the skirt and the bodywork. Right above the jacking point,
On closer inspection, looks as if its bent slightly, the clips are aligned properly.
Is is a common fault??? or is there an easy way of fixing this?? im guessing the person who owned the cupra before me tried to fix it with some sealant as i can see some old stuff left down the gap. Maybe someone messed up when jacking the car previously??
is there a easy fix for this?? or any recommendions for putting it back like a v strong glue/ sealant??
P.S this is def just skirt not sill
thanks again for your help
