RobDon
Pro Detailer
OK so I have the Forge twin pass IC kit with both hoses on one side, but is a single pass intercooler ALOT better for performance, will it run alot cooler, be more efficient and perform better or not make much difference at all?
What temps are you experiencing. Compare your temps to the LCR guys running the forge FMIC single pass. Your car is ouputing similar power to the stage 2 lcr owners.
I think it's a trade off between twin pass IC, and convoluted pipework to make it single pass
Not sure if either will cool better than each other, it's the pipework between it that makes the difference all things being equal
even distribution of airflow within core is an important factor (end tank design for example), dimension of core (depth), and the available core seeing the airflow... twin pass has twice the distance thru halve the cores. Balance of a cool air charge vs losses in pumping it thru. Airflow thru motor is what makes you power, cool charge makes for a denser 02 charge, but worst case scenario is too high and airflow or too small a core will result in power losses, but cooler charge temps.
GRS was an example of an apparent "good" core judging by its output temps.. when reality was it choked airflow badly, and whatever flow could find its way out more than negated any gains in pumping losses. 2-4psi drop even on a small k03 or k03s.
not saying twin pass is'nt ok, its a case of its size being matched to the airflow asked of it.
Ok thanks - I notice that Pro Alloy Ltd. don't do ANY twin pass IC's, all the same side intercoolers are vertical cores and still single pass.
"The flow rate of these coolers is over double compared to a double pass intercooler."
It was comments like that which caught my attention!
indeed - but no good if you have to have 10ft of pipework to get it to utilise it
best option for you would be an Ibiza (sided) manifold to single pass IC
and... something else to consider is the original FMIC core on mine, was too small as the sheer flowrate thru that unit did'nt allow much time for the air to dwel and actually heat exchange.. larger core used (x3 size) and the same flow, slowed down in the core, as well as heat exchange increasing from both more surface area and more dwell time in core.
Forge will make a large FMIC and have dimensions of my core and pipework.
or something with pipework along these lines (but made nicer)
Wayne at Pro Alloy has promised to email me some pics and drawings. He says the intercoolers were developed and tested in conjuction with Jabba Sport.
Incidentally, I wondered if their non-R cooler was similar to their Octavia VRS intercooler. Apparently not.
I quite liked the look of the VRS one - single pass - nice short vertical cores.... :think:
if you can get the air all the way to the end of the tanks..... but still the same 'side' issue and convoluted routing that you'll get otherwise.
I think it replaces the 'squashed' metal pipe in the wheel arch? you'd need to put stops on your steering rack as the wheel will touch it
I like the look of the Pro Alloy kit:
The Cupra version has a new pipe coming straight from the turbo down the right side of the engine to the front.
looks big.
BT friendly no doubt else why bother.
K03 to fill one of these :p :rolleyes:
A few of the vertical single-pass ones look a much better solution for the Cupra, the EVOMS is/was a firm favourite across the pond.
http://www.evoms.com/
I questioned Forge about the single Vs twin topic and asked if they'd ever consider doing any this way (vertical, single-pass), Richard said they were open to any design ideas.
dave, forge forge forge, easy to fit and forget matey.
I hear you. :D
Rob, I see you've actually got one. Is it fitted yet?
A few chases but still waiting...:(
