knotty
Pocket Rocket
Oct 9, 2007
118
Shotts, Scotland
Was driving last night, all was fine for ages then i just happen to be slowing down for a set of lights and pressed the brake pedal to find it really hard to press.... my first thought was it could be this brake servo hose mentioned
http://www.seatcupra.net/forums/showthread.php?t=51097
however... the car is also gone into limp mode aswell at the same time, its spurting on idle and doesnt sound very healthy, it still drives though, aslong as i keep it above idle i can drive so i luckily made it home from where i was however everytime i took my foot off the accelerator it was as if the ECU wasnt keeping the engine alive so when i pressed the accelerator again it like lurched forward a bit.
looking for ideas, gonna vag-com it later even although the engine management light hasn't came on.
Yes, brake servo hose - if it's split it has caused a massive air leak. The engine management light will come on. Check the hose - with the engine running you should hear a new hissing noise from the engine bay if it's split - but you can check it visually anyway!
the engine management light has not came on, ive just checked it with vag-com and im getting 6 fault codes.
Code:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 6K0 906 032 AA
  Component and/or Version: 1.8L 20VT EU3       0002
           Software Coding: 10500
            Work Shop Code: WSC 14646
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
        P0300 - 35-00 - -
16687 - Cyl.3 Misfire Detected
        P0303 - 35-00 - Please Register/Activate
17536 - Long Term Fuel Trim mult.,Bank1 System too Lean
        P1128 - 35-00 - Please Register/Activate
16685 - Cylinder 1 Misfire Detected
        P0301 - 35-00 - -
16686 - Cyl.2 Misfire Detected
        P0302 - 35-00 - Please Register/Activate
16688 - Cyl.4 Misfire Detected
        P0304 - 35-00 - Please Register/Activatecx
Quick start up with the bonnet open and i found the fault. 1 hose had came away from the intake manifold.
Yes it is the hose that the recall was for. It goes from the intake to the brake servo. I had mine into Seat last week and they changed it even though i had a quick check and it all seemed ok. It was free so im not bothered :D
im going in tomorrow to get mine, ill change it myself if they have it in stock. the jubilee clips used are s**t though so i would make sure they use better ones
