OK is it in gd nick ? (cover) Postage shouldnt be any more than £15 but do check normaly will go under standard parcels via parcel force the weight limit is 25kg normaly ..
Is the car happy to run on standard diesel with the map ? i dont have to put the performance stuff in now do i ?
Were there any mechanical faults with the car when u sold it? I take it the suspensions pretty much set at its lowest setting at the min?
i think the Rear is lowered as far as it will go with Adjuster cup still in.
the front i think is 50% lowered.
the dampner rear is set to 14 i think and front i am unsure. probably around 18.
if you turn the adjuster all the way anti clock wise and then move up 4 notches. that is base setting.
car is mechanincally sound. the only ever problem i have had was a turbo pipe split but that was replaced.
i have always ran it on Optimax it was run in on it and remapped on it and spent its life just drinking from the expensive pump, i think it will run on normal might take a long trip just to recalibrate and run smooth as the ECU learns the new fuel.
like i said i can get it all boxed up tonight but some one has offered me £35 plus postage for the engine cover. if this falls through you can have first refusal
lee
lee
Ok lovely , well ill take the suspension from you then ive got it there if i do decide to take the Spax stuff off, & if the sale for the cover falls through i will have that also .. Hopefully i can pm now as im upto 15 posts.. if so ill send you my details an then once you have finalised postage ill send you a paypal payment to cover costs if thats ok..
