CrossyR
Hi, Im Ron Burgundy
Sep 13, 2008
129
Newcastle Upon Tyne
Hi there.
Im going to change my clutch as its slipping (remapped PD130 to 177/313lb's)
Im going to change the DMF to a SMF and fit a standard clutch..
What SMF is compatable with a Ibiza PD130?
Also, is it difficult to do a clutch on a PD130 in a Ibiza? I work in the trade so have ramps and all the equipment necessary to change the clutch.
Crossy
If you replace the clutch wth another standard one, it's very likely to just end up slipping again due to the torque levels you're running through it.
If you're going to the effort of replacing it, you'd be better off with an uprated clutch.
not always....i had remapped A3 130pd which needed a clutch
Fitted a std SACHS OEM one and it was ok.
Depends car to car. My 53 Ibiza 130pd slipped like fook in cold weather but ok rest of time.
SMF will be noisy on tick over - be warned
