muddyboots
Still hanging around
Oct 16, 2002
5,736
What is the most likely cause of smoke for the first few seconds after starting from cold ?
Noticed it on the Passat, I know it's done 90k so I don't expect it to be perfect - just wondered what the cause could be.
Maybe less-than-effective glowplugs, or mucky/worn injectors ?
It doesn't seem to smoke at full throttle and certainly seems pokey enough so I doubt there's anything seriously wrong.
Yeah it's definitely sooty diesel smoke, not oil burning.
The Ibiza would puff a tiny bit out on startup, not much though even at 79k miles. The Passat's on 90k miles and noticeably worse. Maybe I just need to run some decent fuel and cleaner through to clean the injectors a bit.
Stupid question I know, but it's not steam is it? Obviously with it being cold there's going to be condensation in the exhaust system?
Vicky M said:
Does it have glow plugs??:confused:
My HDi (no glow plugs) pug has done 114k, doesn't smoke until you give it a real heavy bootful in 5th, then it trails black smoke.
your hdi will have glow plus, just it wont use them really for starting unless its very cold, modern diesels with direct injection need glow plugs less.
it's usually down to overfueling as mentioned by Stew. Mine will puff whitish smoke on extremely cold days ( 0ºC). It tends to get worse with age...:lol:
Just think of a diesel train on startup ----Puff cloud of smoke..:D
All diesels have glow plugs, they just heat quicker and are less needed. There are many cars that start heating on drivers door opening instead of ignition on (so you won't see the glow plug light).
It's more of a diesel ship than a train, well I feel seasick at times anyway :D
