Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
If it's only 55000 miles on it I would very much think that the turbo is not the cause by means of worn seals or bearings. Maybe the cat or emissions systems are not quite performing correctly. I have vcds-lite and it can be used to check the egr cycle duty and injector quantities to see if everything is as it should be. I know you said it had no fault codes but maybe a run and log would tell you more.
Well the new gasket fixed the fuel smell... Still leaves a cloud of smoke setting off from traffic lights, sometimes virtually none, other times the car following me drops back a good few yards.
Problem is that I've had 2 different mechanics tell me it's not oil smoke, the guy who double checked my timing has been in the job for 40 years and said he couldn't get it any better which rules out injection timing......
Do Shark performance do diagnostic work? Mansfield is not too far really and I'm getting to the point where I just want it done.
