Well ownership of our low mileage late 2006 FR 1.8, we have had it 5 months and what a expensive and not great time it has been. Disappointed is a light way of how I feel about our car.
Issues galore, costs well approx we have spent about £350 each month totalling a nice £1750
that's on just parts and labour not tax and fuel etc.
We had a MK3 on the last reg 02, what a sound solid car, apart from the rear washer pipe it was a dream what went wrong with the MK4?
The car looked spot on when I bought it, but it soon started go down hill after I visited so called tuner of vags, which did a oil change and and fitted a panel filter for £210.
The car supermarket I bought it off did a $hite wheel refurb job, that got worse, they also only changed the belt and not the tensioners or pump so that was next and plugs well the list goes on from there, I won't bore you with the saga.
So 5 months on :-
Service and ITG filter.
Full cambelt and water pump G12 coolant.
Spark plugs.
New dog bone and bush with gearbox oil change.
Wiper blades
New front brake setup
Brake fluid flush and replace
Coil packs
New diverter valve
Removal of dodgy vacuum hose and T piece
Air con treatment
New front boots
Pollen filter
Top mount cover
New wiper arm
New oil and filter, sump plug with correct grade oil.
Turbo to down pipe gasket and bolts.
New rear discs and pads
New polo 9N ariel
Just had wheels off to get refurbed, they need new rear boots and have the following to fit
Genuine Ibiza Cupra rear wishbone console bush
Front powerflex wishbone bush
Genuine ARB bushes
FAI ARB drop links
And to top it off I can hear a whine in the box which isn't right talked to gearbox place and it could be a cost of £450 to £1k depending on DMF. The extended warranty was a real waste time but am going to try with the gearbox.
Bring back our French Clio Sport!
that's on just parts and labour not tax and fuel etc.We had a MK3 on the last reg 02, what a sound solid car, apart from the rear washer pipe it was a dream what went wrong with the MK4?
So 5 months on :-
Spark plugs.
Wiper blades
Coil packs
New diverter valve
Air con treatment
New front boots
Pollen filter
Top mount cover
New wiper arm
New polo 9N ariel
Genuine ARB bushes
FAI ARB drop links
