So what does a cam lobe going feel like? (TFSI)
rudgey
Mk2 Leon TFSI Sport '06
Jul 2, 2008
286
near Midland VW ;)
Hullo all!
Had my 4th year service done on saturday! Fuel filter changed etc. The power seemed down so i hooked the motor upto vag com! Following faults found;
Code:
3 Faults Found:
004248 - Intake Manifold Tuning Valve Position Sensor (G336): Open or Short to Plus
               P1098 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 51669 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 13.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.192 V
012599 - Intake Manifold Runner Control: Basic Setting not Completed
               P3137 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 51669 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 13.0°C
                    Temperature: 15.0°C
                    Voltage: 12.192 V
008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
               P2293 - 002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 51825 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:35:18
             Freeze Frame:
                    RPM: 1333 /min
                    Load: 15.3 %
                    Speed: 1.0 km/h
                    Temperature: 85.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
Readiness: 0000 0000
Now i've sorted the first two, but i'm fearing the last! Ross tech wiki page on the 008851
is ere http://wiki.ross-tech.com/wiki/index.php/18725/P2293/008851
So either the fuel filter is knackered (i watched as it was replaced) or theres a kink in the fuel line or something got knackered as the filter was changed...... OR my cam lobe is worn!
The power is terribily low, altho my s1 revo remap has been put in stock mode now it still seems low even for stock settings!!!!!
Taking an educated guess can anyone tell me a) If i should drive my car and b) what would you put your money on the fault turning out to be!
Marshall
3,256
Bonnie Scotland
Your fuel pressure error seems to be detected at 1km and 1300 rpm are you sure this has not been caused when starting the car after the filter was changed?
I am pretty sure all cam lobe problems anly happened high rpm and full boost.
Does this error delete?
rudgey
Jul 2, 2008
286
near Midland VW ;)
Kevs FR: Yup it's deleted fine I've put it down to the system just being a bit starved of fuel when the filter was changed! Also the mileage, when converted from km to miles was exactly when the service was done to the mile! So yeah! Should really check things through before i panic!
Noel < > Leon: Yup mate it's due on the 14th will get it booked in in the coming week! Thanks for the heads up tho!
