cuprageoff
hi guys please send your thoughts to me they will be appreciated.
my lc sounds like a tractor on startup and i would say gets a little less noisy when warm..
having looked into the matter on here im sort of pointed towards a manifold gasket. got someone to look at it and they couldnt identify a leak or loose bolt in that region. however could only get to 3 of the bolts. since then i have noticed my crankcase breather pipe located on right side of engine has a massive hole in it.... from research i have discovered this could severly damage engine/ loss of oil/ loss in power. could this be also causing the tank like sound...????
i have ordered a silicon replacement at just under £30 apparantly these are made from chocolate and are notorius for failing...
feedback will be much appreciated
